Today my Corsair TX750 finally decided to die. I've just received a Q9650 from newegg so like a true [H]guy I wasted no time and replaced Q6600 with Q9650, checked all the wiring etc and hit the power button. Nothing...not even a beep or an LED light up on the motherboard. I've had a similar problem 2 weeks ago and back then the culprit appeared to be a loose pwr switch cable from the case to the mobo. At least it appeared that way.
So I first checked that and bypassed the whole cable issue just by shortening the two pins for PWR by using a screw driver, still nothing. Checked if it was the ram, took out the gpu even put back the Q6600. I mean my PC was running just fine an hour ago when I powered it down, I didn't think it was the psu. Finally dug up my Coolermaster 650W psu, hooked everything up, hit the power button and the pc started up. Too bad this Coolermaster 650W only has 36A cummulative on 12Vs so I won't be oc'ing this Q9650 for a while.
I bought my TX750 on August 2008 and since then haven't really put it through much load until recently when I bought a GTX 280 last month. When I got my GTX 280, I've oc'ed my Q6600 even higher to 3.897 and ran the computer through some serious stability testing, IBT, prime 95 + furmark to make sure it was rock solid. guess I just got a bad apple for TX750, never seen anyone else have a problem with it and I don't doubt Corsair's reputation for reliability.
Anyways how's Corsairs rma, is it easy and quick, does anyone have experience with it?
