My convertible decision....
BB Gun
Sharing my experience just to add to the group zeitgeist...
I was looking for a new laptop to replace our aging and low resolution TN screen Asus K50.
1920x1080 IPS screen was the first requirement since I try to use these for light photo editing when on vacations. Doing that on the old asus was painful. Since everything new now has windows 8, it had to be a touch screen, as I can't see using win8 without it. more than 4GB of ram and 128GB storage was also a requirement.
You're looking at 700 bucks minimum for those specs, so we decided to look at tablet combos. The Lenovo Yoga 2 Pro, Sony Flip 14A and the Acer R7 for a couple hundred more. (well, in the case of the Lenovo, about 500 more....)
The Lenovo was simply out of our league, pricewise. Plus it has a noted and obvious problem where true yellow shows as an ugly mustardy brown color. Plainly obvious in the store when playing with paint applications. Fatal flaw for the thing.
So it came down to the Sony Flip 14A and the Acer. With Christmas upon us, we decided to pick up the Sony as a Christmas present to ourselves. We decided on the Sony due to the smaller size/lighter weight and its true tablet form after "flipping" vs the Acer R7's slightly angled deck.
The Sony had some documented issues with fan noise and a fidgety touch screen that was solved with a BIOS update, and I experienced both the issues and the fact that the BIOS update fixed them. Things were much better after all BIOS and software updates were installed.
The form factor was nice, the weight was not too bad for a tablet, though 14" is just a tad too big. I think 13" is the perfect size for a convertible, but the good ones are all really expensive.
The big issue with the Sony, for me, was that their digitizer for the touchscreen made the IPS screen behave like it had the poor viewing angles of a cheap TN panel, with about a 30% (guesstimated) falloff in brightness from the center of the screen to the edges when looking at the ideal viewing angle. For a picture guy, it was a deal breaker. I used it for several hours a day for a few days in a row, and just could not get over the light falloff from center. Really annoying.
So, we traded it in for the larger Acer. While the Acer is somewhat unconventional in layout, the positioning of the track pad above the keyboard is actually quite brilliant. You bring the screen forward so the bottom is mated to the deck immediately above the keyboard, bringing it closer for your fingers to use as the touchscreen and completely eliminating the need for the touchpad. When we had the Sony, I noticed that after about 15 minutes of swiping, that I had to keep lifting my elbows off their support to use the touchscreen, and it was becoming tedious. The closer position of the Acer screen to your hands does make a difference in ease of use in laptop mode. It feels quite natural. And the screen itself is brilliant. Rich, sharp, clear, no noticeable falloff in normal viewing, though there is a drop when you go off angle, which again I think is a function of the touchscreen digitizer. But its not near as bad as the Sony.
Also, we noticed between the Acer and the Sony that the Sony screen was just more fidgety in terms of accuracy of touch than the Acer is. The Acer is just all around a smoother, more seamless experience. And the sound is incredible for a laptop. The not-quite-flat tablet mode is actually a boon, as normally when putting a tablet down to use without your hands holding it your looking for something to keep it from being absolutely flat, and the natural angle of the Acer's tablet mode is actually quite useful, eliminating the need for a prop.
The Acer is also quieter in terms of fan noise than the Sony, even after the BIOS fix of the Sony. I think the larger form factor just gives it more room for a better cooling solution.
All in all, the Acer feels like a better computer in almost every way. The only place it "falls down" is its size and weight as a tablet. Since our planned usage for it is not primarily as an ultra-portable media consumption device like a kindle or ipad, it is not a problem for us.
And win8.1 isn't really a problem. Just different, and the familiar desktop is there just like before.
If you're in the market, and are willing to spend around what the Acer and Sony cost, I highly recommend the Acer. Note there are two versions of the Acer, the R7-571 and a newer R7-572. The older model does not have the latest Haswell processor, has less RAM and a documented issue with the wireless that seems to be fixed with the 572. The only place the 572 falls down relative to the earlier one is that the 571 had a hybrid SSD/platter HD while the 572 has just a standard HD, though at 1 TB is double the size of the original version. I would not recommend the 571 due to the shorter battery life due to non-Haswell and the wireless problems - though a cheap USB wireless dongle will solve the latter.
BB
Does the Acer R7 not actually go all the way flat? I thought it did. I was actually considering it. But I think I wanted a Wacom digitizer with Wintab support for software like Photoshop if I went that route which is why I decided against it.
I agree with the touchpad thing. Honestly I've never really liked touchpads all that much. What I'd like is with touchscreens to be paired with pointing sticks (for the precision part). The R7 is interesting in that it also brings the display closer to you as well (larger in terms of view for the same size).
I played around with an R7 at a Best Buy this weekend. Intriguing machine. Not sure how I'd like it for day to day use though. Thanks for the post. It's nice to have people just talk about their experiences with 8.x and hardware designed for it and not get into another 8 debate.
Limited - Both the Sony flip and the Acer R7-572 suppot an active stylus.
Sony's
Acer's
And all touchscreen tabs can use a plain touchscreen stylus. In fact our lastest "thank you" award doodad at work is a laser pointer pen with a touchscreen stylus point on the pen cap.
Honestly, because of the size of the acer at 15", the inability to lay completely flat actually works in its favor. It is simply to big and heavy to hold for long as a tablet style device. The Sony is, too, though less so. Again, I think the 13" flip or Lenovo yoga 2 are just about the perfect size for a tablet/laptop combo.
Win 8.x really, is just a moved start menu. Metro apps are ok, and actually on a touch screen device, metro explorer is truly easier/better to use than any desktop browser. I lived with Win 8.0 for a couple days on the Sony before moving to Win 8.1, and contrary to Penny Arcade's opinion that the new start button is just a software developer's way of saying fuck you, it really does bridge the metro/desktop experience quite nicely. The improvements in 8.1 do make it just enough more useable that there is less of a learning curve and its become natural quite quickly. Metro start screen is just a big start menu. *shrug*
I will say the MS app store is full of dreck, though. Until they fix that, there's no real reason for metro other than that unifying experience mantra. Even then, the desktop still kind of breaks that meme, and I think always will for things like photo editing, movie editing, CAD, word processing, spreadsheet manipulation, etc. But, I'm willing to be shown otherwise...
BB
You can see how far it doesn't go down in tablet mode a few pictures down in this review.
I just checked the lenovo yoga 2 pro out at best buy and it was $50 more than the acer r7. Loved the form factor on both especially the acer but omg the keyboard was horrible compared to the yoga 2. I think I would have picked up the yoga i5 for the extra 50 smackers. I might go do that but I'm not allowed to purchase stuff for myself before christmas. The wifey gets mad.
You need to pay more attention to what you're comparing.
The original Yoga is same price as the newer Haswell Acer R7-572, 50 bucks more than the older R7-571. But, it has a 1600x900 screen, 4 GB RAM and 128 GB SSD. Doesn't meet my spec requirements at the price point I can pay. Not gonna get a windows machine with just 4 GB.
Yoga 2 Pro is 1200.
All keyboards are a matter of taste. I'm not a keyboard connesseur. If it registers a keystroke when I hit it, I'm happy. Acer's suits me fine.
That all being said, if the original Yoga is more to your taste, go for it. It just didn't suit my needs.
BB
I know the specs. The yoga pro 2 i5 ultra hd screen with 8gb ram was at best buy for 999. The r7 was 899.
Was this One but it had 8gb of ram.
It is a $100 more, sorry I was counting my gift card in the price.
You picked the i7 yoga 2 not the i5 I picked and stated in my post. With it being christmas eve I will resist the temptation to get snarky with you. ;)
Lol. Merry Xmas 2 u 2.
Yeah me a culpa. Forgot about that one, cause it didn't have enough RAM or big enough HD. Too many models of both out there.
If you get it, make sure you inspect the color to make sure it doesn't exhibit the bad yellow issue.
BB
Oh ya forgot to look for that at the store. I'll definitely remember to look for the yellow shift now.
Flipping thru the Microcenter xmas ad here and I see they have the Dell XPS 12 spinner screen for $799 with the 4200U and 128gb drive. Did you look at that one at all? I saw the ivy version in person and it was interesting, just wasn't sold on the size/weight for tablet use.
Played with them in the store out of curiosity, but again, the RAM and HD size requirements I was leveling pushed it out of our price range. Seemed like a decent piece of kit.
Its been a while since I picked one up, but I think I remember it being notably heavier than the Lenovo, even though the specs say otherwise (3.4 lbs vs 3.1) so I'm not sure why that is. It did feel quite a bit more solid in relation to the lenovo.
Best Buy has refurb 3rd gen core i5's for 750, not too bad considering a new 4th gen core i5 is 1200.00 at the dell site.
BB
Sony's
Acer's
I was more specifically referring to Wintab driver support which programs like Photoshop (as an example) require for full support like pressure sensitivity. As far as I know currently only Wacom based digitizers support this. Although I did hear something about bringing this support (via emulation?) with N-Trig digitizers I couldn't find anymore information or what became of it.
If someone wanted to spend more the Thinkpad Yoga seems likes a good combo as well. The keyboard supposedly is very good on that likely given the greater size/weight budget for it. Also its more serviceable then the Surface 2 Pro.
I didn't really consider the Yoga 2 Pro for long. I think the appeal to me for this sort of form factor isn't just the tablet mode but pen support as well (digitizer not capacitive, even if it isn't a Wacom).
Surface 2 Pro and Thinkpad Yoga were the most appealing to me but what gave me pause was 1) very high price for 8gb ram configuration, considering the high entry price 2) GPU performance not quite there, considering the high entry price. I wondering if the next iteration will get there with Broadwell GPU improvements (Intel seems to making larger GPU improvements on the die shrinks, speculated at 50% increase atm) and finally making 8gb ram the standard config as opposed to absurdly high upselling markup config. I'm also hoping the Surface Pro might get an improvement to make it more serviceable just from a maintenance perspective (clean dust/heatsink?) as opposed to actual upgrades. The current iterations are supposedly even too difficult for Microsoft to service, they actually won't replace components apparently and your only recourse past warranty is to get a complete device replacement for $400+ (this is actually worse than Apple products lol...)
I did buy a Surface Pro (first gen though) which I haven't opened yet for only $600. Debuting if I should go with that or just a more traditional thin style laptop with discrete GPU (thinking Dell Inspiron 15 7000 or Acer v7 482pg). Although I may look back into the N-Trig based ones if I hear back about Wintab/photoshop(adobe) support. Bunch of unopened mobile devices around, need to return 2 of the 3 :p Tradeoff mainly for GPU performance and possible serviceability issues 2 years down the line (I want to pass on this device to a family member) with the Surface Pro.
The sony and acer active stylus do, as far as I know, support the pressure sensitivity of which you speak, which is why I mentioned them first.
From the acer link above:
The stylus offers high accuracy with 256 levels of pressure sensitivity. The advanced palm rejection capabilities enable the hand to be placed on the screen for a natural writing experience. The Active Stylus also includes 2 buttons for erase and right-click functions.
This thread seems to support that presumption. Even going so far as to say that standard N-Trig pens seem to work fine.
However, I don't know if it is specifically "Wintab" as you're on the edges of my knowledge base.
BB
Wintab API is basically what Adobe uses for full pen support (such as pressure sensitivity). In the past when I looked into it other digitizers, aside from Wacom, did not have Wintab support but only MS Ink support (another pen API). However I heard they were working on this with the N-trig digitizers but I wasn't sure what became of it. The Surface Pro for instance did not have pressure sensitivity support for Photoshop on release as the drivers did not have Wintab support (this was later added).
Are you saying that you have full pressure sensitivity support in Photoshop?
Aha, now it makes sense. Thanks for the education.
You're probably right, then, in that it doesn't support Wintab/Adobe since the N-Trig is the OEM for the Acer. I don't know about the OEM for the Sony.
I don't own Photoshop, so can't report one way or t'other.
BB
