My Conroe build. Opinions?
BigBen
cpu- core 2 duo e6600
mobo- asus p5b vanilla
case- Lian Li V1200B plus II
Powersupply- PCP&C 510w
HardDrive- WD raptor 150 gig
Memory- Crucial ballistix pc2-6400
Video Card- evga 7800gtx
Dvd burner- nec 3550a
very nice. with the p5b you will be able to change multipliers with the 6600, something you cant do with the p5w. but because its a 965 board you probably wont be able to overclock it as well as the p5w.
check out the conroe overclocking database on this forum, for the best bios, cooling, timings, etc. it is a very helpful resource. and while you are there, be sure to check the retail 6600 rankings, where...........
for the cpu i just picked up the zalman CNPS9500, and im thinking about picking up 120mm case fans but i dont kno which ones are good. any recomendations?
tt thunderblade. there are some good very quiet ones also, but they dont move much air. if you can find the tt smartfan 2 in 120mm, those are great. you can let them be thermally controlled, or controlled with an included rheostat, or leave them on full. antec tricool is good, they can be set to low, med, high.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=69&products_id=3311
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=69&products_id=1144
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=69&products_id=1906
this one is pretty cool too
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=69&products_id=2675
and some guys use these too.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=69&products_id=3877
if you look around you can prob find them cheaper. like directron, or frozencpu, etc.
good setup, but i recommend getting a 7900gt for this setup instead of the 7800gtx as its faster and a solid $30 cheaper in some cases. unless, of course, ur taking the 7800 out of another machine, in which case dont worry about it.
