Hello everyone. I have been working on my computer trying to get it boot for 8-10 hours. I have pretty much done things I knew to fix this but none of them work. I googled and can't find answer or they didn't work for me. Also note that all the OS installers are on USB Flash Drives.
I have Kingston SSD and 1TB HDD.
I decided to use Windows 10 on the SSD to play around with it. 1tb had a parition for hackintosh and I regretted because it messed up boot loader so bad. It happened because I removed OSX partition. So I decided to wait till 2 new SSD arrive.
Ever since I have been having trouble to get Windows 8.1 back on the Kingston SSD and even tried on 2 newly SSD that I got yesterday, Samsung 850 Pro 256GB and 128GB. Windows simply refuse to install due to "We couldn't create a new partition." Or a black screen with a blinking underscore.
When it said failed to create a partition, I had to restart and try again. I noticed it did create partitions needed to install Windows. I go ahead and use that then it worked but seems extremely slow. Slower than normal HDD.
Seems like I managed to get Windows 8.1 installed but it just don't feel right. I have to manually boot to Windows 8.1 by using "Windows Boot Manager." I don't even know that I have never seen it before.
Any help and suggestion are appreciated.
I really wanted to give up but I am a stubborn guy and try to fix this as far as my knowledge can take me to.
Thank you in advance.
