My computer makes a loud ringing noise...
Whipsmack
I cannot determine what is causing this high pitch noise. But if I sit next to my computer for an hour or longer and get up and go in the other room my ears will be ringing...it is highly irritating and is probably damaging my hearing haha thats how loud it is...
So i'm wearing hearing protection until I can figure out what the heck is causing this. Any ideas? Probably my freaking video card fan, god that thing pisses me off, I think I started notice it when I dusted it a week or so ago.
its not your pc... answer the phone.. :p
look at the capacitors, i bet you got a couple leaking it may be one in the PSU ... in which case you wont see it, unplug one fan at a time and see if it stops just to eliminate that
hmm only problem its such a high peircing noise that its BARELY audible so i'm not sure if i'd notice it right away...I really only notice my ears ringing after i've used the computer for a while.
Hard drive bearings maybe?
Open the case and put an ear to every component.
It might just be loud noise that is causing the ringing afterwards, like when you escape a party. If your PC is particularly loud, get quieter stuff...
Yeah, how many fans you got running in that thing, and how close do you sit to it? It is more than likely that it simply is to loud to be sitting next to, noise that is in one constant range, like say fans, lawnmowers, anything like that, will make your ears ring. Your ear drums are constantly vibrating at that frequency, so when you enter a quiet room, you notice the ringing. I would also suspect the PC isn't really the cause of hearing loss, but since there is a huge change in sound level from a noisy PC to a quiet room, you simply notice the ringing more.
That being said, you could potentially damage your hearing in that frequency range after prolonged amounts of time, no matter what the volume is, simply because you're always hearing that frequency, i.e, you get "used to it" in other words, your hearing becomes damaged.
