My computer keeps on crashing.
user001
For the longest time (since I've gotten it) my computer has been crashing.
I keep getting "physical memory" errors. This happens when I'm playing a game and then a blue screen comes up that says that a physical memory dump is happening.
I've been told that this could be because my computer is too hot. The CPU on average is at 40 degrees Celsius. Anyone know what's up?
run memtest for you memory...see if it passes. Also, 40c is not at all that hot and my cpu idles at temp and i have no problems. I am sure it has something to do with your memory.
Oh and list the specs of ur rig.
7800 GT 256 MB Nvidia
2 gigs of ram Corsair (2.001 Ghz, can I overclock this?)
AMD 3800 X2
I started running the program and... I think it thinks my comp only has 1.6 gigs of RAM because it asked me open the program twice and to have it use 835 MB of RAM in each instance.
