My computer keeps defaulting to 100MHz FSB?
Slider19
It has run fine for 2+ years now but it's been acting weird lately. Sometimes after a cold boot, the FSB goes from 200 to 100Mhz. I have the Barton overclocked moderately and temps are good.
Is this likely a PSU issue or is the mb going bad?
do any bios settings save themselves when you've rebooted? It could very well be the cmos battery has died and the computer just constantly redetects the RAM improperly.
Does this phenomenon happen when the computer is back at stock clocks?
Yup, even at stock speeds, it keep defaulting to 100mhz on cold boot.
Could this be the mb going bad or a PSU problem?
try using clockgen in windows to set the FSB higher, if it crashes/can't do it -- then there's some kind of problem with RAM / CPU / MB.
Additionally, a good idea would be to set Memtest86 to run over night to check if there's anything wrong with the RAM.
A quick run of Prime95 to check the CPU, would be swell.
Finally, if you're checking the FSB speeds in Windows -- try a bootable Linux distribution or a BartPE Windows disk to see if your Windows is FUBAR.
It can be a sign of hosed capacitors in either the PSU or the mainboard...
I've run memtest, no errors. Will try prime95. Once I use clockgen or bios to set my FSB back to 200mhz, my computer runs fine. It's just at cold boot that this keep happening.
Also this just happened to me an hour ago. I was playing a video and my computer just rebooted. First time this has happened.
What mobo do you have. You might check to see if your jumper fell off that puts it in FSB safe mode. My old MSI k7n2delta had 2 jumpers for that. One, when open, put the comp in safe mode and made it boot at 100MHZ. The other was a three pin jumper...it could be changed to put the FSB at either 133 or 200 MHZ I think. (Make sure everything is grounded properly too.)
This may be a long shot, but have you tried swapping out the CMOS battery? Your board has to be at least 3 years old (I should know...) :D
