My computer is lagging...
mknkt54321
i have an HP build that supports up to 4gb of 667mhz ddr2...
I have installed an athlon dual core 5000+ and 2gb of pny 800mhz ram and 2 gb of samsung 533mhz ram. Running windows xp and getting lagging while searching interenet and sometimes with other programs, but not as much as while searching internet. I'm using a wirless USB adapter for interenet. Do you think this might be a Windows, Memory or Internet problem? or do you think it's something different. I also have malwarbytes Antimalware running up to date and have run a complete scan and have no bugs or any of that stuff. I've also ran CCleaner multiple times to clean any registry errors... maybe that's what the issue is??? please let me know yoiur thoughts... thanks!
This sounds like it is mostly an internet / browser configuration issue. I'd try another browser and see if that helps. Depending on your network configuration, try power cycling your modem and/or router. Hard to say specifically what it is without more detail.
