My computer is jiggling me.
BMWlover
I have a frosted glass table where I have the computer set up. The vibrations from the Centurion 5 case (the rig in my sig), wiggle my mouse a little, and when using the mouse I constianly feel vibrations going through my hand. Can anyone recommend a certian kind of material or trick to stop the vibrations? Thanks
Wow, I wish my computer would do that to me. You should feel special...
Try anything soft like cork or rubber feet.
Or if you want the easy way out, go to Bed Bath and Beyond and pick up one of those rubberized placemats, that should do the trick. If you have a couple equal height mousepads laying around, that would probably do the trick too.
