Not sure which way to go next, but sure is making me mad. I got a had a pretty good thing going the for a while there. I just bought an AMD 64 3000 Venice and Abit VA8 with a gig of some fast Crucial ram. And I bought a used Radeon 9800 Pro from someone at work. If that was the end of the story I would be very happy, but it wasn't.
I had two 80 gig WD SE 7200 rpm IDE hard drives with my setup. For some reason one of my hard drive died on me. I tried to write zeros to that drive and mistakenly formated the wrong hard drive. I lost some data that I had saved back from 1997. That wasn't the happiest day of my life.
I replaced my 80 gig drive temporally with an older 40 gig drive drive I had. Since I had a 64 bit processor I figured since I had to reinstall my OS I would try Windows XP 64 bit version. I worked great at first, but my buring software didn't work as well as several other programs. Call of Duty ran great in Windows XP 64 bit. I delt with that for about a month, but I thought I would possibly try a dual boot setup since I had two drives. The older 40 gig actually had an old install of XP on it, but for some reason wasn't given an option on booting to pick which one to run. If I went into the bios and told it that the I didn't have a master hard drive it would boot to the 40 gig drive first and load XP. Strangely it still let me use the 60 drive, but made it a secondary drive and it put the 40 gig as my C drive. When I redid the XP install on my 40 gig drive my problems started again.
My system started doing some crazy things, locking up and rebooting. It didn't make a difference weather it was 64 bit or regular XP. With all my system reinstalling I figured I had a virus, found a low risk trojan virus which I removed, but I still had the same problems. So I backed up my data (the little I had left). I think low level formated my 40 gig drive and tried to reinstall windows. I was able to install windows, but then my system went down and I wasn't able to succesfully install a stable XP on my 40 gig. Bad 40 gig right? that's what I first though.
I tried installing formatting my newer 80 drive over and putting xp back on. I got it installed, but the same problem. My pc would lock up and I would have to shut it off and sometimes, when I was restarting it, it would just reboot again and again at least once, but sometimes more. Other times it would reboot on its own. This was happening like 10 times a day. I thought since it was turning off it might be the power supply. I have a ThermalTake Purepower 430 which never was a problem before, but it lacks power connecters for serial harddrives as well as for PCI-express.
I went to Best Buy and picked up a Antec TruePower 2.0 430-Watt power supply and couldn't get my system to even post. They had a Neo 500 Watt for $50 more, but I was told the 430 would work just fine. I got errors 9.C and 9.F on my motherboard which I come to find out is that Antec TruePower 2.0 don't work very well with my motherboard. So back to the drawing board, right well moving everything around I broke my 9800 Pro.
I broke the extra power connector off my video card while I trying to redo all my connections.
So back to my old Geforce4 Ti4200 for the time being.
What the heck should I do next?
does it sound like a CPU or motherboard issue?
And should I try exchanging the Antec supply for the Neo 500 Watt or just return it?
hmm
I just realized I bought my motherboard on 10/17/05
I never updated my bios or cleared my cmos
there was a bios update on 11/30/05
hmm
