Ok i just bought a new comp and it will hard freeze randomly in some games, and will also do a gradual freeze when running certain p2p programs while running voip programs. It doesn't hard reboot, it just freezes. And when it returns to desktop out pops the "Active Desktop Recovery" screen, that tells me that windows had an error.
I am so confused that i don't even know where to start.
I am running xp pro service pack 1a fully updated
I am not using the Nforce gigabit, i am using the Marvell Yukon with the drivers from the cd, no the newest ones because i have heard that they are screwed up. Using version 6.66 of the nvidia chipset, but not installed the ethernet nor the sound or firewall.
system is as follows
Antec P180
Asus A8N Premium
x2 4200+
2GB OCZ Platinum
XFX 7800GTX 490/1300
Creative Xfi platinum
exos WC
NEC dvd R/W
PcPower&cooling 510 express
2x80GB Seagate sata
4x200GB Seagate
3x250GB WD
1x300GB Seagate
2x320GB WD sata
I have tried everything but a format, and right now i really don't want to have to do that, but it is in the realm of something i might do if there are no other suggestions. Also i know that right now the x2's have a problem with a lot of games and not running them properly.
So now for some suggestions
Antec P180
Asus A8N Premium
x2 4200+
2GB OCZ Platinum
exos WC
NEC dvd R/W
2x80GB Seagate sata
4x200GB Seagate
3x250GB WD
1x300GB Seagate
2x320GB WD sata
