I was gone from home a couple weeks ago and my dogs knocked my computer down. All that I could see that was wrong with it was a broken fin on the 120mm power supply fan. When I try to turn it on, everything flashes for a split second then nothing... I've tested the power supply using the black wire green wire jumper trick and it works fine, but I have not tested my motherboard with another power supply. So I'm wondering if it's my power supply has something wrong or my motherboard??? Oh yeah I hold the computer power on button for 4-5 seconds (as to turn it off) and release, then press it again and everything flashes again, so I'm thinking it might just be the power supply, but not sure!?!?! Please Help!!!
Thanks!
Thanks!
