my computer don't speek
gedan
hello, friends; my computer don't speak.
the peripheral one is installed correctly, the codec does not have problems but I do not feel a sound. but what happens
help me.
my computer: thoshiba satellite pro 6000 pentium 3,whith windows XP
Ali audio Accelerator WDM driver: is correctly
codec: is correctly
even if I have tried to verify the presence of virus-Trojan without succeeding the history smells to me
Check all cable connections
Run DXDiag.exe (its in the windows\system32 folder)
If you have a sound card (not onboard) make sure its in properly, or try it in a different PCI slot.
Not sure about you're prob.
But if it helps any, GSpot an excellent free prog. to find out what codecs you have installed and what codecs any particular file might need.
boys thanks, am successful there updating the drivers on the site of the THOSIBA. I have been attached by the horse trojan DOWNLOADER.ISTBAR.CW
im guessing english isnt your main language...
btw if you guys didnt know, he has a laptop
