my comp keeps shutting down after inactivity
indokyne
i can surf / game / etc for hours but if i leave it unattended / inactive for a long period of time, it just shuts off.
running a fresh install of XP Home SP3.
on numerous occassions, i've come back to my pc after 20-30+ minutes to find it shutoff.
i have no screensaver
under the power options, i've set everything to "never" for:
- "Turn off monitor"
- "Turn off hard disks"
- "System standby"
under hibernation settings, i un-checked "Enable hibernation"
upon turning my pc back on, i never see any messages saying Windows was not shut down properly.
what else should i be looking for?
Maybe someone else in the household is turning it off to save power?
I don't know.. you could sit in front of it while it's idle and see what happens? If it cuts off, or goes through a shutdown procedure... etc...
- "System standby"
I have the same problem on my wifes toshiba laptop. There are numerous problems with xp sp3 i made thread about people to list problems if they saw any but nobody responded.
