OK this is weird. And hasn't happened until recently.
My Surfboard 5120 modem has started causing extreme static on channel 3 when its plugged in. BUT ONLY when:
1) it is fully connected to the cable provider
2) there is a lot of data transfer happening (it gets much more intensely staticy)
For example, if the modem is plugged in but no systems are turned on, there is no static. If I'm on the pc and I am navigating sites with heavy image load, there are white static lightningbolts shooting across the screen for a few moments. If I am downloading torrents, there is NONSTOP static shooting across the screen and a crackling sound.
The channel is still there...and the image between the static lines shooting across the screen are not affected. The quality is still there but its like lightningbolts of white static and crackling are shooting across the screen, making watching that channel very unpleasant.
I'm going to replace all the wires and maybe the 900mhz splitter I have in place. But still I would like to know what is the cause of this, so maybe someone out there can help me
Edit: also, this ONLY happens on Channel 3. Channel 2 is unaffected, and all channels over channel 3 are unaffected. ONLY CHANNEL 3!! What the heck ?! =P
cable from the wall goes to the splitter, then one cable plugs directly into the TV and the other directly into the Modem.
ALSO other TV's in the house are affected. But the static is much much less noticeable on those TV's when there is high data transferring.
