needsnumbers
- Jan 10, 2007
As reported by the P3 "Kill-a-watt" device, the surge of startup is 340va (that's volt amps, not watts) <- edit and then 270 during startup and a normal resting 250 as I'm writing this. Games I haven't tested but assuming the efficiency of the video card I'd bet it doesn't get over 340va.
The specs; ASUS P5B-E 1.01g, E6300 at 2.8GHz (400MHz fsb) air cooled and at stock voltage, Corsair 2x512MB PC6400 @ 1:1 ratio, eVGA 7600GT slight oc, 2x Seagate 250GB 7200.10's in Intel Matrix raid0/0 array, WD 250GB, and a NEC dvd burner.
All this powered by a Fortron FSP group AX400-PN
Rock solid and soon to be water cooled for silence. FSB will be moved to ~450MHz when I figure a cost effective solution to cooling the northbridge.
I just thought I'd share that information with those looking at power supplies.
I have a friends mini-atx AMD 3600+ X2 that's running on a 300w Fortron PSU but that is using on-board video, not oc'd and only 1 hard drive.
I think some people are spending too much on PSU's that they are never going to need. Do your research and get a higher quality lower wattage PSU and be happy you spent less and got more! Just because a unit is rated at 600 watts doesn't mean it's a clean 600, let alone a clean 300. Notice my system is oc'd and it's running on a 400 for months
Imagine what the requirements would be non-oc'd. I'm guessing 40-50watts cooler (remember video card also oc'd). That's around 200 watts doing normal computer use. Now gaming is a whole nother story. I might reply to this thread if I do further testing.
