My board is alive!!!
kiajoon
I have a brand new GA-D31-DS3L, my first Gigabyte board. Oh man what a nightmare.....
Right out of the box it works fine for a few hours, and then it reboots itself for no reason at stock. Now it refuses to switch off - once I plugged in the PSU it starts up and hangs there, not booting. There seem to be a constant closed circuit on the board, even when there is no CPU, VGA card, RAM or any wires connected. Board is out of the case and just plugged into the PSU and running. I do not need to start it up.
I had used a screwdriver to start up the board out of the case for initial setup. Could it have caused damaged? I was using the correct pins.
Is there remotely I can do about it? Or it is just plain RMA time?
I have taken out the battery even. It does not help.
I meant to check and see that it's not set to enable. This would cause some boards to power on, but not do anything. Other boards just won't do anything it's set though.
Checked that. Jumper is correct.
