It can accept a 1080p signal, but it cannot scale it properly when using 1:1 pixel mapping. It 'overscans'. I'm not exactly sure what overscan means, but I think it's where the scaled image doesnt fit the screen correctly.
so if i watch a new released DVD on this monitor it's gonna looked stretched or just a couple very small black bars on the top and bottom?
Can anyone tell me what 1080p HDMI monitors correctly display 1:1 pixel mapping with the PS3? I've read the 37 Westy is a no go. And I've seen the question asked about the Aquos.....I've read we're splitting monster nose hairs...LOL
I know this is an older post I'm replying to, but I'm curious, has anyone else tried this? Does it really work? I think I have just encountered the "black out" problem with my new FP241WZ. It's happened twice so far in the 4 days I've owned this monitor... both times with drivers that I had installed that were not the ones that came with my card.I had a problem with my new FP241WZ monitor flipping out and going all black for a couple of seconds then jumping back to normal. This would happen multiple times.
I think I found the cause. My nvidia video driver was not using out the proper sync polarity. I went into the advanced timings dialog and changed both sync polarities to positive. No problems since. I know that the monitor is telling nvidia to use positive sync polarities via DDC and in the monitor device driver, but I still had the problem with both an older driver and the latest one.
Enjoying my new display
LeRoy
Higgy, if you send my your PS3, I'll try it out on the LG and BenQ 24" monitors... *grin*
Jim
Well, I tried creating a custom timing profile in the NVidia control panel and I still got the blank screen thing. I've now switched everything back to defaults, including using the cable that came with the monitor instead of the expensive Monster cable I bought.
Dang, just when I thought I found a good monitor or one with small problems easily fixed....![]()
I'm back to the version that came with my card right now and hoping the problem doesn't show again. But if does and it's just a matter of changing the sync polarities, then that seems like a simple fix. In order to do that though, I assume I have to create a new custom timing profile, correct?
Sorry, I'm going to ask a bunch of stupid questions. Does the blackout happen with all inputs? How long does it usually happen? Does the monitor act like it's trying to change resolutions? Could you guys give more details of your operating systems and hardware? I'm just looking for a common point. I wonder if any Mac users have this problem?
Hmm does the blackout problem occur with those that use Windows Vista?
It happens on XP with my setup but I haven't seen it happen on Vista yet. The scaling is also broken on XP, so maybe this is a driver issue?
The reason you are experiencing this blackout is almost certainly due to your video card.
Your Benq monitor has a resolution of 1920 x 1200 and so the graphics card has to work harder to generate the image. When you have tested it on other monitors they were both 1280x1024 which would put less strain on the graphics card.
In answer to your question, yes you are the only person I have heard of that is having this problem, probably for this reason – that it is not a problem with the monitor.
The reason it the Benq monitor is working ok using the D-SUB connection is because again this puts less strain on the video card.
I would recommend doing a simple test. Try to just look at your PC’s desktop using the Benq monitor. If this does not cut out or go black then there is nothing wrong with the monitor. The fact that you have told us that this happens when you run a 3d game implies that the fault must lie with your graphics card. The Monitor has no idea what type of image it is receiving. It is no harder for it to display a moving 3d image than a static image. If the monitor had a ‘blackout’ problem, then this would occur no matter what type of image you send to it, 2d, 3d , static, anything.
I hope this clears up this problem.
Which is a load of bull![]()
