Well, I finally moved into my new about 3 months ago and now I can say that I am pretty much all finished with the datacenter that I have in the basement...
It took a long time and many late nights, but it's all finished. The day of the move, I had to drag all the stuff from my old house here and slap it all together to make sure it was working for Monday. As time went on, I organized it more and more... But enough talking, let's begin the tour!
This is the main shot of the server room, anti-static lenolium floors for the server room floor, epoxy coated concrete for the rest of the area. The ceilings are not done yet, but will be very shortly. We have 3 seperate 20A circuits feeding power to this area:
This is our corporate portal Sun Enterprise 220R Server. It has all the front ends for the Oracle 10g database. It is a dual 450MHz UltraSparc with 2GB RAM and 2x 36GB SCSI Hard Drives:
This is a Sun D1000 StorEDGE JBOD drive array, there is only 2 72GB drives in there for now, but I am looking to expand the storage in the near future as our Oracle DB grows:
Next down the line is our HP ML350 Server which is running Windows Server 2003 Standard w/ Exchange Server 2003. It's our main mail server as well as message store for Cisco Unity Voicemail:
This is our WAN equipment in the same rack as the servers mentioned above. From the top down... First is the Marconi TNX-210 ATM Switch/Router from our carrier Cablevision Lightpath. The fibers on the left are the Single Mode fibers coming in from the demarc (seen later on in the tour) and the fibers on the right go to our switch router (seen later). Next is a Cisco 3662 Router which is maxed out with Flash and DRAM. It serves as our data router as well as our voice gateway to the PSTN for the Cisco CallManager system. Below that is a Cisco PIX525-R Firewall/VPN Server which is used to aggregate our other remote sites into this one. Below the PIX is our Cisco 2600 Dial In Router for remote access and below that is a Cisco VG200 PSTN voice gateway that is used for local POTS lines (911 Calls, Alarm, Etc...)
Next rack over is my switching rack. The patch panel ontop connects all the data cables in my house. Our central switch/router is a Cisco Catalyst 5509 with dual power supplies, RSM routing module, 3 10/100 Baldes, ATM Blade and a 9 Port GigE GBIC blade.
Here is a close up of the switch. I forgot to mention that it has dual supervisor engines:
Below the Catalyst 5509 is two Siecor fiber patch panels and also a patch panel that has cross-connect going to the server cabinet:
Next, we go to the server cabinet. In the lower half of the cabinet, you will find a nice array of servers. Here is the types and their purposes:
IBM X330 - Network Monitoring Server (Debian)
IBM X300 - Media Storage (Windows 2000 Server)
Dell 2650 - Cisco CallManager
Dell 2650 - Cisco Unity Voicemail
Dell 2650 - Citrix MetaFrame Presentation Server
Dell 2500 - Windows 2003 DC + DNS + DHCP + WINS
Dell 2500 - Windows 2003 DC + DNS + DHCP + WINS + FTP + TFTP
Artistic shot?
KVM:
The rest of the Solaris Cluster. 3x Sun Netra X1 front end servers and another Enterprise 220R Server. This is our primary Oracle 10g server:
Now we can take a look at the wall behind the racks that has all of the telco equipent:
This is the Cablevision fiber demarc that I mentioned earlier:
And we can open up the access panel... top 2 fiber pairs go to the TNX-210 and the last pair goes to a Fiber-Copper T1 converter for our PRI:
SmartJack for the PRI T1 and also punch blocks for Lightpath and Verizon:
These are my punch blocks for the Cat3 phone cable runs for the house and the office:
And that concludes the tour of the actual server room, now we can take a look at my office which is a couple feet away from the server room....
Overview of my desk:
My Cisco 7971G-GE Gigabit IP Phone:
My HP Compaq NX9600 Laptop:
Overall shot of my office:
Well, I hope you all enjoyed the tour and I welcome any questions or comments!
Artistic shot?
KVM:
