My ATI 4850 CPU Limited?
oogly
Hi guys, I just recently upgraded my Nvidia 7800GT to a ATI 4850 and my processor is a AMD Opteron 165 @ 2.4ghz. Since I am only a 19" LCD, my max resolution 1280x1024. My question is am I not fully utilizing the power of my 4850 or is my Opteron 165 good enough? Thanks!
I'm kind of curious on what people thoughts are too. Im on an opty 170 with a 7800gt running at 1280x1024 haha.
simple answer is yes your cpu is holding you back. to what extent will depend on the game and your settings.
your gpu is pretty slow compared to current offerings so you arent in the same boat as the op.
I have an X2 @ 3ghz and it is definitely a bottlenecking my 4850 at 1280x1024. In some games, like GRID, it doesn't matter since I'm still getting ~50 fps w/ 8xAA and everything maxed, and in TF2 I had a minimum FPS of 100 with 24xCFAA. So even though its CPU limited, it doesn't really matter. In Crysis, however, I get less than half the FPS I should be (~20s instead of 40s), so in that case it hurt my experience. World in Conflict had no issues - again, I maxed out the settings, cranked up the AA, and the game was completely playable.
So far, the only games where I've found my relatively slow CPU to actually have an impact on playability is in Crysis and most likely Supreme Commander (haven't played in since I got my 4850, but I remember my 7950GT being held back a bit in the game - have yet to verify this, however)
My X2 6400+ slightly bottlenecks the 8800 GTX I have in certain games and situations and its slightly slower than an HD 4850. I'm sure your CPU is limiting you a little as well. You're still going to see a huge improvement in GPU bound situations though and the price is cheap enough for them. Why worry? ;)
