My APC doesn't work. Just wanna get something that does.
MrDowntempo
My PC (which uses a 1000watt corsair PSU) and all it's accoutrement is hooked up into a battery backup. Some days everything works fine, some days the backup shuts off the system. (the opposite of what it's supposed to be doing). The backup beeps and the system shuts down and everything else in the house, even on the same fuse is running fine. Clearly this battery backup is a PoS. It wasn't the smallest one in the store when I bought it, but it definitely wasn't the biggest one either. (don't remember actual specs). In any event, I'm thinking of getting rid of it, or maybe trying it in the living room under less load. Since I can't really afford a BIGGER battery backup (i spent like 80 or 100 on this one by APC), instead I think I'll just go with a high quality surge protector.
Any recommendations? I don't know enough about electrical currents to tell a good one from a jip. I love my PC, have a lot of money tied up in it, so I mos def wanna keep it protected. I know I probably need a better one than the strips I can pick up at WallyWorld. At least 8 outlets preferably more. Also, I live in Florida, the lightning capital of the US. :D
Any suggestions or recommendations? Surge protectors with PC users in mind? or an affordable but functional UPC? Any advice would be a big help, Thanks!
Why don't you just move it to the surge protector section of the APC unit instead of the battery backup part? What APC unit do you have?
I second this - What APC do you have? I wouldn't call it a POS just because you are constantly overloading it, APC is one of the better brands of UPS you can get. Sounds like you might have a 350 or 450, I'm a little fuzzy on the model numbers off the top of my head, but those are the units that look like over sized power strips. I don't know how much power your PC is pulling, but if you have a 1000W power supply, I'm betting it's way more than those little UPS were ever meant to handle. I have a 350 right now and I know it can't handle anything more than a low end desktop. I use them on things like my networking equipment.
When did you buy the UPS? You may be able to get it replaced under warranty.
Most of the $80 to $100 APC units out there are 500watt or less.
A mid to high end gaming PC and monitor could trip one of those under heavy load.
Its hard to make recommendations when the only detail we have is your PSU. Sure its 1000W but what are your system specs? What model UPS do you have? I'm betting you simply got a UPS that isnt designed for the load you are putting on it.
This is a 1500VA UPS, it supports loads up to 865W. Depending on your system it would most likely be enough.
http://www.newegg.com/Product/Produ...2101419&cm_re=apc_1500-_-42-101-419-_-Product
This is the one I have.
My system is an 920 i7 with a 5870 and a buncha fans and a couple of HDDs. Also have the monitor, printer, router, and speakers plugged into it. Cable Modem is actually elsewhere, I admit I'm calling it names in frustration and it probably is underpowered. Still I can't really afford a $200 battery backup though, that's why I'd rather just spend $60-100 on a real quality surge protector.
I have that exact same UPS and I cannot come up with any complaints about it.
It says I would get 6 minutes of runtime at full load though. :mad:
20+ minutes at idle with my monitor switched on. I'm sure it would last longer if I wasn't home and my monitor was off.
If you have a laser printer hooked to that battery backup you will continually trip the system. Additionally your going way over the power handling capabilities of the UPS system.
Yikes dude! :eek:
Never plug speakers or printers into a UPS. I would only recommend the computer, main monitor (if you have more than one) cable modem, and router. Everything else should be on surge only outlets, but even with those changes you're going to be pushing the 200W capacity of that thing even at idle. That is way underpowered for what you need. A 450W UPS would probably get you by, but you're way over spec with what you have now.
UPS with 200w limit and a system with a 1000w power supply? Those numbers definately don't add up.
First and foremost, NEVER put a laser printer on ANY battery system. Separate surge protector only, and if possible, separate circuit (this is why I love wireless laser printers). Use the Antec Power Supply Calculator http://www.antec.outervision.com/ to get a rough idea of how much DC power your system actually uses, then multiply that number by 1.25 and that's a rough guess on the AC circuit draw. For example, if the APSC says 700w, 700x1.25= 875w, which would need a 1000VA UPS. If you want your monitor to run off the battery too, you'll need to go even higher.
The reason for this is because in the event of a brownout (which you can mitigate by having a UPS with a built in line condition, or voltage regulator) or blackout, the battery has to be able to supply the entire system with power, if it can't, then it's as if the system wasn't connected to a battery at all. Think of this like trying to start a car off of two or three AA batteries... simply not happening.
In short, if you want any battery protection at all, you're going to need a MUCH bigger UPS than what you are currently using. Take that little 350va and connect your modem, router and monitor to the battery ports, your speakers to a surge only port, then buy a new UPS for just your system (after you work the numbers from the link I posted above).
Yep, there is a severe mismatch between your UPS and your current rig. The UPS is only rated to handle a maximum practical load of only 210W (and that's counting everything, including the PSU's draw itself, which is about 500W total at maximum load at even stock speeds). That far exceeds the 210W maximum for that battery back-up.
The BE750G has a maximum capacity of about 450W (converted from the 750VA rating). That still might not be enough for that system, especially if overclocked at all.
I have an overclocked i7-950 with a GTX 470 and four hard drives. Although an APC 1300VA (780W) UPS would have been adequate for my particular system, I got the higher 1500VA (900W) unit for greater peace of mind.
You might also check out refurbups.com - something like APC-SUA750-Smart-UPS-750 would be a start, though if you really need a 1000W power supply in your computer you are going to want a 1500VA .
And as was mentioned never plug in a laser into the UPS. If you can't return the 350W you have now use it to plug your monitor, etc. in to and just plug your computer into the new one.
Your monitor, printer, and speakers should not be plugged into the UPS.
Lots of good stuff to go through here, thanks! Also, I forgot that half my battery backup is a surge protector and half is battery backup. So looking at it again I see only the monitor, PC, and router were plugged into the battery backup side. (speakers, inkjet printer, external HDD and everything else was just on the surge protector side. However what's odd is when the battery backup shut off, even the stuff on the surge protector side shut off. I'm gonna look and shop around with your suggestions of better battery backups. Going refurb might make what I need affordable.
Would my current battery backup be able to handle a 42" tv, and a HTPC with a 650 watt PSU? The PSU is prolly weaker than that just overvolted though. That system is running a 9800gt and a intel quad core (socket 775 don't remember which particular one, but its a later model) If so I can move it into the living room. If that's still overkill I'll move it to where the modem is and perhaps move the router over there with it.
Thanks again for all the great tech advice. That's why I come here, and you guys never let me down. =)
Again, a TV is something that should not be connected to a UPS. UPSes are for preventing your computer from shutting off spontaneously, so you don't end up losing or corrupting data. If your power cuts out for a few seconds or minutes, you generally don't want something power-hungry like a TV sucking up energy that could otherwise be used to keep your computer running for longer.
That depends. If you have dirty power it may be a good idea to plug your expensive TV/monitors in a long side your PC. I do in any case. Well I don't plug my, lights, laser printer, or mini fridge in for obvious reasons, but just about everything else gets plugged into one of the two UPS with AVR in my den.
If you have dirty power, you should really be using a line conditioner, not a UPS (or a line conditioner in conjunction with a UPS if you're powering something that needs to be constantly online). The AVR in most UPSes is pretty basic, and a dedicated line conditioner will do a much better job.
I beg to differ on the monitor part. As a former WoW raider I could stay online for up to 14 minutes if power went out during raid time, easily enough to finish a boss fight. :D
The real issue is the circuit. If plugged into a wall then the circuit power is based on what wires and breaker you're using, if everything is plugged into a UPS (regardles of which side it's on) then you're only capable of using what the circuit max is for the UPS. The PC -alone- is enough to overload that circuit without even considering the other items.
If it were my system, I'd run the hdd and monitor on the battery side as well as the speakers (if they were <20w) inkjet printer on surge protector side, and get **at minimum** a 1000va UPS for the system, 1500va would be a better choice.
If nothing else was connected to it, the HTPC might be ok, since those are low power draw. The rated wattage for the PSU is still almost double the max wattage for the UPS, but if you built the HTPC properly with low wattage/low voltage components then you're probably OK. HTPC+TV on battery, no way. HTPC battery and TV surge protection, yea, you're fine.
And +1 to what was said regarding line conditioner for dirty power. +1 again for UPS with AVR. If dirty power is the issue then just a cheap battery is not the answer.
Obviously, you planned ahead and bought a UPS with enough juice to handle it, not some 200w UPS with a 180w monitor attached + system. I'm right with you though. 1500va Cyberpower UPS with AVR, ~12 minutes of uptime during blackout, and I have lost power during WoW raids. My modem/router/VoIP router are on a Cyberpower 350va with AVR in the other room, enough for about 45 mins during blackout (which is nice since hold times are high for utility companies during outages).
Rule of thumb, plan ahead, and don't skimp on protection.
What good is the 6 minutes a battery backup provides you to save your data if you can't see your data on a screen to save it?
I would buy a toy ups for the monitor alone.
At home I have a server grade APC UPS 1400XL that has a > 1 hour runtime for my main desktop computer. With that I still do not have the monitor connected to the UPS but I can remote in to shutdown from a laptop.
Just to throw this out there, but APC isn't necessarily the best UPS, even for the price. The last time I bought a UPS, the APC models all seemed to be offline/standby units, unless you went way up to the 'Smart UPS' models. I ended up getting a Cyberpower unit that is line-interactive (better, as I understand it) in the same price range. We use Eaton at work on the workstations, also line-interactive.
Also, I've had 2 APC units give up the ghost, the 2nd of which was only after a couple years. Very small sample size, but I now have a bias against the brand when other options exist.
Get a UPS with a display so you can see (rough) wattages, then aim to not get close to maximum capacity at full load. My i7 950 (@stock) with gtx275, 4 spinning hard drives, 2 ssd, 2 24" monitors, router, can pull ~400 watts easily under load, and my UPS is good for 600 (1000 VA). If you're near the ceiling every time you fire a game up, that makes you worse off than not having a UPS at all, since you can get powered off at any moment.
&#3232;_&#3232; I do not live in a world where UPS battery backups are a disposable items. I don't need a setup so stable I can run a CS server during the zombie apocalypse. I just want to be able to save my game/files and shut down when the power goes out.
And I thought my 1800VA on a dedicated circuit, on the leg with the lower draw, was overkill.
