My aircooling setup needs work
Soarin
Okay i am running a complete air cool setup. I have a M59 classic case with 5 fans. The 1 120mm fan in the rear next to I/O shield blowing air in. 1 120mm fan on side window blowing air in and one fan on top of case 120mm for exhaust. Cpu fan, and the PSU fan. The psu is bottom mounted with the fan blowing hot air out and down under the case. I am thinking of adding another 120mm exhaust on top and a 120mm intake in front. My temps are with HW monitor and Speed Fan. Okay i need these to drop any ideas, short of liquid cool?
CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.6.0
Monitoring
Mainboard Model GA-880GA-UD3H (0x0000031E - 0x9B551EA8)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8720
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8720
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 20 08 00 00 00 FB 00 40 20 00 00 01 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0228
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.02 Volts [0x40] (CPU VCORE)
Voltage 1 1.49 Volts [0x5D] (VIN1)
Voltage 2 3.36 Volts [0xD2] (+3.3V)
Voltage 3 5.00 Volts [0xBA] (+5V)
Voltage 4 12.48 Volts [0xC3] (+12V)
Voltage 5 -7.17 Volts [0x70] (-12V)
Voltage 7 3.63 Volts [0x87] (+5V VCCH)
Voltage 8 3.17 Volts [0xC6] (VBAT)
Temperature 0 41°C (105°F) [0x29] (TMPIN0)
Temperature 1 36°C (96°F) [0x24] (TMPIN1)
Temperature 2 39°C (102°F) [0x27] (TMPIN2)
Fan 0 3771 RPM [0xB3] (FANIN0)
Fan 1 1015 RPM [0x299] (FANIN1)
Fan 2 1834 RPM [0x170] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 99 pc [0x7F] (FANPWM2)
00 11 10 40 00 FF FF 00 37 FF 87 58 0F 27 B4 99 6E
10 FF FF FF 73 D7 81 80 7F 00 02 01 FF FF FF FF FF
20 40 5D D2 BA C3 70 FF 87 C6 29 24 27 80 1C B3 B3
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 95 00 FF FF FF FF
50 FF 2A 7F 7F 7F 50 00 00 90 00 04 12 60 00 00 00
60 00 14 41 27 90 03 00 FF 00 14 41 23 90 03 00 FF
70 00 14 41 20 90 03 00 FF FF FF FF FF FF FF FF FF
80 00 00 E4 01 00 00 FF FF 00 00 00 00 00 00 02 00
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Gigabyte DES
Voltage 0 1.02 Volts [0x40] (CPU)
Register space LPC, base address = 0x0220
Hardware monitor AMD Phenom II X4 955
Power 0 20.50 W (Processor)
Temperature 0 39°C (101°F) [0x134] (Core #0)
Temperature 1 39°C (101°F) [0x134] (Core #1)
Temperature 3 39°C (101°F) [0x134] (Core #3)
Temperature 2 39°C (101°F) [0x134] (Core #2)
Hardware monitor Radeon HD 5770
Temperature 0 51°C (122°F) (GPU Core)
Hardware monitor WDC WD5000AAKS-00D2B0
Temperature 0 42°C (107°F) [0x2A] (Assembly)
Uploaded with ImageShack.us
Rear intake + front intake may cause problems, you'd have to test it and see what happens. What CPU cooler are you actually using? If you're on stock cooling then just get a better cooler and that'll drop the temperatures a lot, then you can experiment with case fan orientation and see what gives you the best temperatures.
