Well, after posting over in the memory section about how hot my Ballistix run I decided to take (cf)Eclipse's advice I wanted to add a fan to my ram.
Every ram cooling device out there is screamingly gay. The neon crab, thermaltake's heatspreader with fan. (Yeah, I want a buzzing fan mounted directly to a stick of ram. NOT)
So I came up with the idea of mouning a metal plate with standoffs to the two mobo mounting holes on either side of the ram sockets. I used two brass standoffs to secure the board, then used two 2" screws and 3 1/2" spacers to mount a strip of aluminum besides the sockets. From there I mounted a fan to that strip. (Yes I know that fan is ugly, it's the only clear one I had)
The only downside is it hides the cool LED's on the Ballistix. Another reason I wanted a clear fan. At least it still has a cool light effect.
I'm a little paranoid about the fan causing the standoffs to vibrate loose from the case so I stuck a couple of rubber washers between the aluminum plate and the fan.
I actually mounted the fan where I did on accident, any lower and it wouldn't clear my HDD. Lucky call there..
Now I just need a better looking fan, and to paint the aluminum piece. I suppose I'll make it UV green to match my unoriginal case lighting/scheme.
Let me know what you all think!
(Mobo is ASRock 939Dual-SATA2 and case is the older Antec full tower SOHO server case)
-scoob8000
-scoob8000
