My A64 3200+ won't OC
Well, I have the an Abit K8T800 Pro motherboard with an AMD Athlon 3200+. I have tried OC'ing it in the BIOS, and I can get it up to 218MHz FSB without it crashing, but it is unstable. I have tried full voltages, and it still doesn't work. If I go higher than that, it crashes. There is no obvious way to adjust DRAM timings in my BIOS, well there are a bunch of different ones I dunno if they are relevent, but I will give some pics of my BIOS, and if someone could help, I would be very grateful. My temps don't go above 45 load, and 37 idle, usually around 36.
The main BIOS page:
The advanced chipset features (where you can adjust the stuff for RAM):
The OCGuru in the ABIT BIOS:
The other specs of my computer are in my sig.
Which revision AV8 do you have? Your AGP/PCI lock may not be working.
Otherwise, you could just have a sh!tty chip, though this is less likely.
It's just a AV8 K8T800 Pro, I got it off newegg last week. Also, if the PCI lock isn't working, how could I make it work? It says it's locked at 66MHz, which I know is max.
yeah, you probably just got a shitty chip. even people over at XS are having trouble with getting the newer (week 49 2004 and later) to over 2.2ghz in some cases.
edit: especially the ones from newegg...
:mad: that's bull, ugh. So I can't configure any of those RAM clocks to make my OC better? Or should I just play around with it.
There isn't a revision # printed on the PCB anywhere? I've read that they may have needed as many as three different rev's to finally fix it. If yours doesn't have it working already, you can't make it work yourself- you can only exchange/RMA your board for another one, hopefully newest version.
let me guess, you just got the CPU? i have 2005 week 1 and its a CRAPPY OCer. also PLEASE resize ur pics, i am on dsl but its hard to see
Try setting your AGP to 67MHZ. From what I understand 66=locked to FSB. Anything else will lock it to that frequency. I bet that your AGP can withstand a 1Mhz overclock. I would very well be wrong, but it will only take 2 minutes to find out.
Rules for OC-ing a A64 CPU.
1. memory, with memory modules with Samsung TCCD or Winbond BH-5 chips You can OC normal. Any other type of memory You will have to use memory divider. It will not kill preformance to much cause they have on die memory controller, just find a sweat spot. Memory modules with other chips but also labeld LL aren't dooing shit in LL settings with AMD 64 bit CPUs. Use looser memory timings it will bring You further.
2. AGP/PCI lock set AGP to 67 MHz and then it will not follow HTT and memory clock.
3. Lover a HTT multiplier to 4x if Your wished OC aint higher then 250 or 3x for higher speed. HTT 5x = 1000MHz DDR = efectivly 2000MHz. 215 MHz memory with HTT 5x= 2150 MHz= to much for chipset and mobo lines. If BIOS has no HTT multiplier option it has HTT speed option and 5x =1000MHz, 4x =800 etc.
4. Use slightly bumped Vcc (CPU voltage, Like allready 0,05 V will help)
5. Have good PSU
6. Have some luck and CPU made in good week (although let we say all Winnes doo like minimum 2400MHz wich is not bad at all)
MD
I think the 67MHz AGP setting still requires your chipset to have some independence between the AGP freq and the FSB. K8TPro has a working lock, but very few boards implemented it properly- including most AV8's.
Not sure if it applies to your mobo or not, but with my MSI board I have to change the SATA port I was using for the hard drive from 1 to 3 for me to be able to overclock at all. Now it's purr's along at 266mhz fsb.
yeah, sorry about the pics, I forgot to resize them before I posted them. And yeah, I just got the CPU last wednesday. Also, I have a good PSU, it's a fotron souce bluestorm 500W PSU, with dual 12V rails, @ 18 Amps each I think. But I will try some of the stuff you guys posted, thanks.
I'll post in here, you have more replies. I have a very similar setup to you. Same CPU, Mobo, and even power supply. I'm starting to think that the chip is crap. Mine is also brand new, got it from ZipZoomFly and not The Egg. I highly doubt this is a PCI lock problem. I'm willing to bite that the 66/33 lock may not work on this board, but I have used the manual dividers running it in the 230FSB range to set them at 66/33 and its the same crap. Windows is stable, just no 3d longer than 10 minutes.
I've been running at 230FSB for over an hour in Half life 2. I set mine to 74Mhz Fixed and this seems to have helped when nothing else would. 74MhzAGP and 37mhz PCI isnt hardly anything out of spec. No where near as bad as the good ol' days running a 440BX chipset with limited dividers. I'll report back once I test higher bus speeds.
Edit: worked fine for awhile...back to locking up. I hate this board or CPU. I knew I should have went with the Neo2. :mad:
shadowbreaker513 said:
Bah, get 2T off of there. That's the last thing you want in your RAM timings.
He could have been doing that just to eliminate the possibility of his RAM timings holding him back.
Its a board issue. Even with a shitty chip you will be able to get 200mhz(230 to 250 FSB) more. I have used the ABIT AV8 and the Asus A8V. Both sucked ass even the latest revisions. Way to many options to adjust that arent even needed or neccasary. The MSI Neo2 Platinum is way better to oc with. Infact if you look at all the OC records and the such for A64 platform they have been done on the K8N Neo2 Platinum. Also for someone that posted earlyer about SATA connect to use the AV8 only has 2 not like the Neo2 that has 4.
Now with that in mind what cooling do you have?
What Vcore have you run the cpu @?
What Vdimm have you run the mem @?
I would Change the Dram timing seeting from Auto to manual.
Run mem timmings @ 2.5-3-3-7 @ 2.65 up to 2.8 Vdimm the mem you have should easily do this @ 250 FSB @ 1T setting
Run AGP @ 67mhz
Make sure cool and quiet is off
As you increase FSB you need to increase Vcore
Be sure you lower the LDT HTT multi. to 3.0 keep it under 1000
Dissable aggresive timming
Start off with Low CPU multi like from 6 to 9 or even lower and then push your FSB while doing so adjust Vcore and Vdimm accordingly. Watch your temps and as mentioned earlier be sure as FSB goes up LDT/HTT multi goes down keep und 1000.
You look like you have parts that are just fine But I still say the board is the Issue.
If ya have any more questions give me a shout. But I think if it were me I would get a Neo2.
The Cpt.
Typically at 2.3Ghz and higher I have run the CPU at 1.45v but have tried as high as 1.5. Temps never go over 50c as my room is pretty cool.
The vdimm is almost always set to 2.8v as I dont think its going to hurt my corsair sticks.
The most stable setting I have found so far is 230FSBx10, fixed 66/33, 1.45Vcore, 1.8vDimm, and 2x HTT. Even at these settings, my in game performance in HL2 feels choppier than my Athlon Mobile @ 2.63Ghz on NF2Ultra board. So far this has been one big 300+ dollar downgrade.
I have a thermalright XP-90 with a panaflo 92mm fan, idle temps without adjusting anything are about 37, and load are around 46. I will try adjusting those settings, and I may just RMA this board, and get an MSI K8N Neo2. Thanks.
Thank you all so much, so far I can get to 2.35GHz stable (235MHz FSB x10, VCore 1.5V, RAM is at 1T, 2.5-3-3-7 @ 2.8V, with 66Mhz/33MHz AGP/PCI lock), but I still haven't messed with a few settings. If I have more questions, I will ask, but I am gonna go see if I can get higher.
hmm, well actually it's only really stable @ 230Mhz FSB, and it'll posat and boot windows @ 240 MHz, but it is unstable as hell, and it will not post at 250 MHz...
