the network has 3 comps, 1 connected to router and modem, 2 connecetd to usb adapters
basically there are 2 problems.
onw problem is it very often disconnects forcing me to unplug it then replug it. or right clicking it and going into view avaliable networks and telling it to connect(which sometimes doesn't work)
so anyway about the second problem, a while back my dad got a new computer, the network wouldn't work when he switched the modem from my comp to his new one,(it was at mine because his old one was too old to connect to his work, while mine was new enough). The indian tech support guy said to enable the wep so he did.
later my internet which was connecetd with a usb adapter and teh other comp connected with a usb adapter started going really slowly. His comps internet was fine.
I changed the channel and teh interenet was fast again, but then got slow a couplde hours later so I ahve to change the channel every couple of hours.
Should I just convince my dad to chuck this thing and get a 802.11g router, if so by what company.
Or are these problems fixable.
