My 800D
usesoap
I didn't realize I had my camera set to 640x480. And I sure as hell ain't lugging that
hernia box back to the shop today so these will have to do. :mad:
I really like how you ran the 24 pin cables and sata cables, most people use the cable routing holes that are closest to the motherboard. The overall look is very symmetrical and sets it apart from other 800d builds where the builder tries to hide as much of the cables as possible.
Great Job!
Why thank you "JT Garr" There are six sata cables there. I thought they turned out well.
Very nice and clean. I really like that blue and black color scheme.
It looks great! Is it me or does the video card look slightly slanted towards the right?
It's a heavy card and sags a bit. Not sure what to do about it. Any suggestions?
Sweet man. I really like the tubing coolant color.
IMO, should've passed on the 120mm rad, and gone for the 360mm on the top. :)
I was wondering about the choice of the rad myself. Other than that looks pretty clean.
Nice build. That motherboard is great for color coordinated builds - caters to blue fans everywhere.
Here's a nice comparison,
Difference of 8-10 degrees. That's even more important when you are overclocking. Your build is sweet, dont get me wrong, but with the single rad, you might as well have gotten an H50.
I had an H50 before the custom build. I will look into a bigger rad.
Yep just it's a bit up close. If you could catch the whole case with the side panel on, that would make a great shot of the build and the 800D
Great cable management btw
Thanks man. I will see about gettin a nice high rez shot.
I am changing the color scheme to black and green. These
two fans were my first mod. Well as you can see there is a new power
plant within. Silverstone 1000 watt Strider. Gonna try and sleeve the
entire psu in black and bright green.
I sleeved them myself. You can get the material to do your own here :)
http://en.mdpc-x.com/mdpc-sleeve.htm
They are in Germany. It takes about 10 days to get your stuff.
If anyone knows of a place here in the states that carrys the
high quality stuff please let me know.
Here is the vid card, post paint. Turned out quite well I think.
New reservoir and green UV fluid coming later in the week.
24 pin and sata cables sleeved. I lengthened the 24 pin power
cable from 22" to 31". Also added the green Feser UV fluid and
new reservoir. I know the res is crooked. Gonna work on that
tonight.
Looks great, but I had to do it, Over 9000hrs in MSPaint.
tonight.
Nice rig, looks familar!;)
