My 3dmark scores.
Shawn
Here they are 01 Se - 14208, 3dmark03 5485.
here's my system AMD ANTHLON 2400+ @ 2.18ghz 145*15 @ 1.75 Vcore, 512 PC2100 ram. Ati Radeon 9800PRO. ABIT NF7 V2.
WHat can i do to increase my scores b/c i have been looking and its seems to be a bit low. Just wodnering what can i do. SOme people suggest Buying new Ram. http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-305&depa=0 PC3200 and doing 200*11.5 2.25ghz At first then make my way up. WHat should i do buy a new system later on or buy new ram Now!? Thanks in advance
Low latency pc-3200 & a much higher FSB should do the trick.
Yep, high FSB will make a huge difference. Also, don't forget to squeeze every ounce of OC you can out of your 9800.
yea, ive seen ppl with higher clocks but then they get lower scores, dont know why. :confused:
3Dmark is probably just more hungry for bandwidth than raw processor speed.
