My 3400/3500 debate?
lost0822
Here’s what I got together.
Case:
http://www.newegg.com/app/viewProductDesc.asp?description=11-129-144&depa=0
PSU:
I have a antec 430 true power already, that’s should be sufficient right?
CPU:
http://www.newegg.com/app/viewProductDesc.asp?description=19-103-426&depa=0
Mobo:
http://www.newegg.com/app/viewProductDesc.asp?description=13-131-498&depa=0
RAM:
http://www.newegg.com/app/viewProductDesc.asp?description=20-145-440&depa=0
Video Card:
I already own a eVGA 6800GT
DVD RW:
http://www.newegg.com/app/viewProductDesc.asp?description=27-152-032&depa=0
DVD Rom:
http://www.newegg.com/app/viewProductDesc.asp?description=27-131-119&depa=0
Floppy:
http://www.newegg.com/app/viewProductDesc.asp?description=21-103-116&depa=0
Thermal Paste:
http://www.newegg.com/app/viewProductDesc.asp?description=35-100-007&depa=0
I also already have a sound card, keyboard, mouse and monitor.
First is there anything I am missing, like I said this will be my first build so if you need to suggest something and embarrass me please do! I mostly game but do very light home movie editing.
The way I would approach that would depend on when you plan on moving to PCI-E. If you think that your NEXT motherboard and CPU will be something with PCI-E, then stick with the 754, since you will be upgrading again anyway....
Unless you plan on trying to keep your CPU when moving to a new motherboard platform, then you might be better off with the 939. However, I remember hearing about the new Nforce4 motherboards with PCI-E being released in a 754 flavor as well. Second opinion?
If you get the 939 mobo then the new dual core CPU's are supposed to fit straight in with may just a bios flash.
Just my 0.02P worth.
Luck........ :D
