Cantonious
- Jun 22, 2003
At a friends house so disregard the kitchen table..
Finally get to put this computer to work!
antioch said:I was thinking of getting that LCD (even though it will make my wallet a bit lighter than I'd like - if ya know what I mean) and I was wondering if the power butotn light is like the Samsung 204B in that it is blue, not green. Or, is there no light at all? I haven't been able to tell, lol.
Other than that, how do you like the monitor? How is the stand? Looks a bit strange, not as sexy as the Dell 2407FPW, but then again the dell in isn't so sexy just because it's a dell.
Ah, while I'm on the subject, how would you compare it to the dell? Also, can you try the component inputs and see if they bleed/give fuzzy images like the dell does.
Sorry, I'm trying to decide between this and the dell, which is a lot cheaper.
DL-DVI would serve you no additional benefits than a single link would for this monitor, same goes for very 1920x1200 monitor out there at the moment (until lcd can handle 14 bit and beyond for each colour).sniperchicken said:......... I did purchase a third party DVI-D dual link cable though, the one packed with the monitor was DVI-D single link. Just something to keep in mind.
darklight_tr said:I just did a quick price check and found the 244T as low as $940 shipped.
antioch said:Also another question, a very important one! It's a bit hard to explain but I think you'll understand what I mean. Does the 244T have a function where you can, for example, play a game at 1600x1200 resolution and *not* have it stretched to be 1900x1200, but instead display black bars on the sides? Or even something smaller and not have it be stretched both vertically and horizontally, but be surrounded by a black box?
antioch said:Also, can you post a straight-on shot with the monitor at both it's lowest and highest heights? If only 1 picture is possible, then I'd prefer the lowest height, as I like keeping my displays low.
Thanks a ton! I'm looking forward to buying the display.
Oh, and another question. Have you watched any DVDs on it yet? The Cnet review slammed it for having crappy colors during DVD playback, yet good colors during gameplay. Of course it said there were pixelations on DVD playback, but thats DVD technology's fault - DVDs have always shown granulation and noise on higher ends monitors, CRTs included. Anyways, can you comment on DVD playback?
antioch said:You're gaming on linux? Hehe. At least that looks like windowmaker.
Anyways, don't you notice the image lag? People are complaining complaining complaining and it's scaring me away from a widescreen monitor. I noticed you picked up a dual-link DVI cable in order to get rid of the lag, but I'm wondering if you could switch back to the single link DVI cable and compare. Also, do you know if the monitor supports dual-link DVI? I realize that the plug will accept a dual-link cable, but does the hardware actually work with it? Because this input lag issue is scaring me off, lol.
That and I heard something about the 7900GT not supporting the "boxed/bordered" output.
What graphics card do you have?
Bez said:Outrig, what graphics card are you using at the moment?
I will test the monitor elsewhere, that way it eliminates the screen, otherwise I guess Im
getting a different video card!Never once did I read anywhere about this issue prior to choosing this card. oh well.. thanks for the feedback guys. I can play games in 1280 x 1024 with everything maxed out, but for day to day desktop use, the res is just too low.
Bez, it can't be the screen because I was using 7900gt just like you albit dual 7900gts but that shouldn't make a diff. I just used the cable that came with the monitor and in the display control panel I just move the slider until its 1900 x 1200. Like you said, try it on another comp so you eliminate the screen as the issue as it likely is not the cause. Forget about using dual dvi or whatever, just use the one that came with the screen. it worked perfect for me
