Not completely built yet, but this is my plan, anyone have any input or things I should lookout for or change?
Going to be running an OC'd E6600 on a ASUS P5W DH. My radiator will not be using the ambient air inside the case, but instead pulling air from outside the case, through a custom duct inside the PC, and then out of the top of the case. (Worklog posted Project: Savage)
Pump: MCP655/DD-D5
Rad: Black Ice GTS 240 Stealth
WB: Swiftech Storm
Reservoir: ??
No GPU Block right now, going to be using a 512MB Nvidia 7900, figure I can always add a GPU Block later if I want.
Pump: MCP655/DD-D5
WB: Swiftech Storm
Reservoir: ??
