Putting together my first small(er), and first ever low power (cpu) system in 10+ years.
Ordered the items I needed today: 4/18/2014
Usage:
Business machine.
- Outlook, FireFox, Dreamweaver, misc biz apps and maybe photoshop from time to time
Goals:
- Cheap, Cheap, Cheap
- Use low power (but not super picky based on price)
- Small/easy to move/easy to hide depending on where it settles
- misc other things like warranty time frame, etc.
Since the original goal was to be cheap cheap, and had no real performance goals in mind other than business usage I had planned on the Intel Pentium G1820 for $49. However, due to reward points the CPU was replaced with the G3420, purchased elsewhere and came in $9 cheaper overall. I was also going to go with the ASROCK H81 ITX Motherboard for $59 but it only came with a 1 year warranty. (I've had issues right after the 1 year mark with motherboards a couple times) I upgraded to the H85m which was $75 but has a 3 year warranty, and substantially more features should this need be built out into a more powerful workstation or even storage system.
I went with G.Skill Ares 2x4gb 1600 1.5v RAM for $69 as I've had good luck with G.Skill in the past on other builds, and the price seemed right (in current times, arghh),
Case: BitFenix Prodigy (White)
I've wanted this case for a while, and figured now was a good time to love it or hate it
Fans:
Not sure yet -- might try none, or just an intake... wanting to go silent as possible, Suggestions?
Power Supply: EVGA 500W 80PLUS Certified ATX12V/EPS12V Power Supply 100-W1-0500-KR
Purchased due to 3 year warranty, and price. Way overkill for this project, and my other spare PSU is in another system. If it doesn't work out I'll go SeaSonic most likely.
Data/Storage:
(1 or 2) Samsung 830 128gb SSD
I have these leftover from another project, and they have less than a handful of gb ever written.
1 Blu-Ray or DVD drive I have sitting around
Parts hopefully will start showing up on Tuesday, and the pictures will start!
Usage:
Business machine.
Goals:
Fans:
Data/Storage:
