SameSuspect
- Jul 6, 2005
For so many years iv been trying to build a pc but have never got round to ordering. Finaly iv saved the money to make it happen!
I will be using it for nothing but computer gaming, im on a smallish budget so im looking for performance at low cost. Im used to playing games with low graphic details but would love to be able to play bf2 at 1024x768 with everything turned on with a good smooth fps
If you think im choosing a wrong component, PLEASE let me know as i dont have the brains to learn the technical stuff
case - Thermaltake VB1000SNS
power suply - Enermax Noisetaker 485W EG495AX
motherboard - Asus A8N-E nForce4 Ultra (Socket 939)
cpu - AMD64 3200+ (venice)
Heatsink - Akasa AK-855-BL Copper Base CPU Cooler (Socket 754 & 939)
Ram - Corsair 1GB DDR Value Select PC3200 CAS2.5 Kit (2x512MB)
Graphics - HIS Excalibur ATI Radeon X800 GTO ICEQII TURBO 256MB GDDR3 TV-Out/DVI (PCI-Express)
Hardrive - Seagate Barracuda 7200.9 80GB ST3808110AS SATA-II 8MB Cache
im also buying that Arctic Silver 5 Thermal Compound stuff for the cpu
will this setup run bf2 the way i want it? also would the corsair value ram slow things down?
