Get either a 8600gt or 2600xt. Either card is great for what you need and your price range.
Heh, he said PCI (unless he meant PCI-E).
I haven't seen either of those cards on PCI, but if they were, I would get one just for the fun of it! Because it's fun!
The best PCI cards I've ever seen are X1550 and X1300's.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161074
http://www.newegg.com/Product/Product.aspx?Item=N82E16814129062
There you go! If you need PCI-E, just post and I will try to help you. Good luck!
Whats the best pci card for around 100? Thanks
i only play CS and WCIII so i dont really need a badass card.
ok so im going to just get the 8600gt. I know it supports directx 10 but do i need to have it to use its full potential? Im running XP and isnt DX10 only for vista?
