MX518 Wheel Dieing - Need new mouse
WhiteZero
Had my Logitech MX518 for awhile now... and today the wheel has started dieing. First the down-spin doesn't work, now the up-spin is splotchy, and even the click is going out.
Should I just buy another? Is there something newer/better out there I should look into? The only other mice I've used are: Microsoft Intellimouse (Original, loved it, had 2), Razer Diamondback (didnt like it), and a Razer DeathAdded (didnt like it either).
Generally I don't like ambidextrous mice, only right-handed ones.
Any recommendations?
Is the new Logitech G500 going to be any good?
EDIT: Damn!! The G9 is only $50 on Amazon... probably going to go for that one.
Well, you're not losing anything by taking it apart (so long as you're careful not to misplace those tiny metal springs on the wheel!). You might just have gunk stuck in the wheel.
Call Logitech or use the online RMA system or whatever they call it.
With the serial numbers under your mouse you'll be able to get a new one for free. It shouldn't be a problem even if you've lost your receipt.
