QFT.GeForceX said:Razer. I've tried both. I don't believe the rest of the posters did above.
that it is. So when are the plasma's due to come out in retail stores?aironite said:Whichever fits your hand better. Plasma is a damn good looking mouse though.
burningrave101 said:The MX518's ability to adjust sensitivity on the fly is nice.
You can say that again.aironite said:Whichever fits your hand better. Plasma is a damn good looking mouse though.
that's what i thought. the shape looks so similar. I've owned that exact mouse before and the way i hold the mouse, it works perfect. (holding onto the mouse with your finger tips and not your whole hand).zekez said:If you can't find any kind of DB to feel up, this logitech is probably the closest thing to it. Same basic design and height, the DB just slopes off the back a little longer.
I don't know... but I'll find out when mine gets here. (I am on a dual-boot Gentoo/Win2K system).1c3d0g said:Does anybody know if the Razers even work in Linux? Or do they require special propietary drivers to work correctly?![]()
Thanks.Drucifer said:I don't know... but I'll find out when mine gets here. (I am on a dual-boot Gentoo/Win2K system).
LunchboX3904 said:
KoolDrew said:Definitely the MX518. It is the best gaming mouse ATM.
