mx518 adjustment woes (OS & SetPoint sensitivity, DPI)
Hello everyone. I recently picked up a Logitech MX518 mouse to replace my MX500. I am using this for gaming.
I saw lots of threads about how gamers noticed an improvement in mouse performance immediately after starting to use their new MX518. Unforunately, the experience has been the opposite for me. I never noticed any real difference when playing a single-player game, but after a few sessions with CS 1.6 online, I am having the toughest time adjusting to this mouse. It's so frustrating.
My settings:
- mouse DPI at 1600
(I figure, this is one reason I bought the mouse in the first place)
- CS in-game sensitivity 1.0-4.0
(been trying different values, but last session I was at 2.0)
- Windows mouse control panel setting is a notch or two below the midpoint
(with 1600DPI, feels most comfortable when using the mouse on the Windows desktop)
- SetPoint sensitivity setting is around the midpoint
- mouse acceleration is not enabled, either with the Windows mouse control panel, or in the SetPoint config panel
- for Mouse Game Settings in SetPoint, I have Game Detection enabled, and Speed and Acceleration set to the SetPoint value.
My problem is I find the mouse to be too touchy at times. When coming out of spawn, I move the mouse around and it feels OK. BUT, when I flick my wrist to quickly get the crosshair on a target that just appeared, my crosshair always overshoots the target. That would sound like mouse acceleration is on, but it's definitely disabled everywhere.
(As an aside, I generally like to be able to do a 180 by moving the mouse less than a foot, without having to lift it up... seems like mid-sensitivity gaming to me, no?)
What I don't understand is whether the Windows control panel setting will have any effect on my mouse when in a game. For the SetPoint "Speed and Acceleration" option, if I choose to use the SetPoint implementation (vs. OS implementation) what does that mean - that the Windows mouse speed settings are essentially disabled?
Or if I enable "Game Detection" and choose to use the SetPoint implementation (vs. OS implementation), does that mean that the SetPoint implementation will override the Windows settings ONLY when I'm playing a "detected" game?
Or is in-game sensitivity, in all cases, a combination of Windows control panel setting + SetPoint settings + in-game settings?
All I know is when playing CS, I'd switch the DPI down to 800, and it felt a little less wild when I'd flick the mouse around. But I think that defeats the purpose of getting the MX518 in the first place. I also do realize that some of this could be adjustment on my part - you can't necessarily expect to go from a mouse you've been using for years to a new one and "get it" immediately.
I should probably RTFM (I'm at work ATM), but I thought I'd ask ahead of time. There seem to be many MX518 fans out there... I know many of you don't use SetPoint at all, but I'm hoping I can get some settings advice from those of you that do.
With Setpoint, you can set individual settings for both windows and seperate games. it is pretty much endless AFAIK on the number of different profiles you can have set up. Of course this is coming from the G-5 Version of Setpoint (meaning all the options that may or may not come with the mx series).
I am pretty sure Setpoint overrides the windows sensitivity...but I am not 100% sure.
I've never use setpoint for my MX518. The built in windows drivers are good enough and function as I want by default.
ive used setpoint and dont like it. If you leave your mouse at the highest dpi at all time i see no point in it either. You can set the buttons in game and you dont use the adjustable dpi (though it is still adjustable in three settings without setpoint) so why bother with setpoint?
