MX1000 won't work with Abit-AV8-3rd Eye...
HighwayAssassins
I recently had to put in my backup AV8-3rd Eye in because my DFI is fucked up...before I got the DFI I had many mouse problems with my MX1000 not working because the mobo wouldnt recognize it...although it would work here and there...it seemed to stop working after a long period of non-use.
When i got the DFI it worked fine, and now when i put this mobo in i get the same problem...so its obviously the mobo. Anyone know how to fix it?
Thanks.
'So its obviously the mobo' sorry your logic isnt correct. Something is wrong with your MX1000 not your motherboards, because to you knowlege the mobos were working fine but the only thing that didnt work was the mouse.......your mouse is messed. get a new one.
Are you using it on USB or PS2? I was using mine on my USB for awhile and looked at logitechs website for a potential fix. They suggested plug it in to PS2 , worked fine from then on.
Installed AV8...mouse works intermittantly.
Installed DFI nF3...mouse worked fine for 2 months.
Installed Av8 again...same problem with the mouse.
Its obviously the motherboard, seeing as how change the mobo, problem goes away.
When I put on the PS2 adapter, the mouse works like it should, except none of the buttons work...how do i get the buttons working with PS2?
Garric said:
Make sure you install the drivers from the CD.
I think it is pretty much a given that this guy has done that. It could be that the USB port on his motherboard has a problem with the connectors, or it could actually be that the drivers for the mouse are not compatible with that motherboard.
I recently took an A+ class, and the professor told us that he had problems getting a mouse working with his computer and when he went to the website for the mouse, he found an addendum saying "Does not work with ABit motherboards".
They should really have that on the box but, que sera sera.
I would advise him to test that USB port by plugging a printer or something into it and seeing if they work. If they do, it is probably a compatibility problem with the motherboard and the mouse, and they just will not work together.
I have tested other USB devices and they do work fine...but PS2 seems to work fine...
I guess the MX1000 dont work with Abit mobos...oh well.
THX for the help guys
