MX 700 And Software
KINgGh0sT
Alright I've had my MX Duo for quite some time but I just recently formatted and came into a situation whitch is incrediblly annoying. When you are in a window the mouse accelleration is normal, but say you close it it drops down to none. Or even random times this happends, any solution?
Try installing or uninstalling that game detection utility that they have for download on thier site. That might help. I've seen that happen in the past but I can't remember which windows it was in . I use the Dinovo keyboard and mouse now and with the setpoint drivers I dont have that problem even when I plug in my mx700.
Ditto. Bloated crap. You get the same performance without it.
some times you've just gotta live with it. I use the MX700 without any acceleration. Check if your using the latest version and all the usual stuff.
