Mutliple Monitors , Background?
Slickgreen
Fist off i have dual monitors hooked up to my AIT X800 PRO
How do i get my desktop backgroup to extend to the other monitor
instead of just mirroring it.
Please let me i know it should be easy
thanks
thanks
yes you are right...it is easy...very.
go to your display properties
click on the second box for the monitors
click extend my windows desktop to this monitor.
set the res, and color settings...
enjoy dual monitors.
also it would be in your best interest to look into a program called ultramon...it's ment for multi monitors. lets you set different backgrounds for each monitor and lets you extend your taskbar onto the second there are like 10000 other things it lets you do.
