GJSNeptune
- Mar 31, 2004
My brother works at a studio, and he wants to set up a file server over a network between his Mac and the owner's Windows machine. It'd basically be a scratch dive for uploading project files instead of burning discs to get the files to the other machine. He doesn't seem to want backups, as he's satisfied with keeping the original data on the individual machines. I can probably convince him to go with RAID 1, so I'm thinking a solution with two WD6400AAKS drives.
The question is, should I recommend a NAS solution (with or without disks), or build one myself? And which one would you recommend? Buffalo or Hammer?
