Skull_Angel
- May 31, 2010
hey guys, about to finish deciding on a final components list for some core parts (cpu/mobo/ram) and ran in to a slight stump when choosing the ram.
the kits in question are these two mushkin kits;
enhanced blackline 3x2gb 1600MHz - $140
enhanced blackline 3x2gb 1600MHz - $150
normally I'd go with the first kit and run it at 1.65v because it's more than likely they're the same kits, it's operating voltage range listed as 1.5~1.6 kinda made me scratch my head a bit. I know most ram will handle over-volting within the motherboard's safe limits well, I've just never used a kit that listed an operating range with an upper limit under that point.
basically, gogo first kit?
