Mushkin PC4000 and CPU-Z?
drizzt81
Hi guys,
I just got my Mushkin PC4000 RAM to finally upgrade my system to a gig. I already have a Mushkin PC3500 in there, but the PC4000 was cheaper (do not ask me why). Anyway, I got it from newegg, put it in my machine and manually set the timings to 2-3-3-6, which my PC3500 did fine and according to anadtech, the mushkin should be able to handle as well, since my bus is only at 200MHz.
Upon loading UT2K4, my PC crashed. So I set the timings back to "by SPD" and loaded up CPU-Z 1.21 to check on the timings. I see my PC3500 ram fine, but my PC4000 ram gets reported as PC3200. Is this normal?
Maybe someone else could have a look, if they have the same ram and let me know.
my Config:
AXP2500 @ 200MHz bus (locked multi) on an Abit AN7.
never midn ust talked to mushkin on the phone and they told me this is normal.. i tried to delete the thread, but was unable to :(
It's probably because the chip's SPD is listed as PC3200. My HyperX4000 is listed as PC3200. All that really means is your running PC3200 that was certified to run at 4000 speeds.
