Hey,
After finally caving, today I switched my *generic* PC2700 with Mushkin Level 1 PC3500 (2x256).
However, whether i got bad sticks or they're not setup right, i'm getting worried.
At stock, DDR400 it boots and runs fine. I could pump my generic 2700 up to 230FSB without any problems, however the Mushkin doesn't seem to like anything above 220, and when it's running, using SiSoft Sandra it gets less than my 2700 did??
My 2700 got 4988 / 4993, my mushkin gets 4803 / 4815
It's running on:
P4 2.6C
IC7-MAX3
Mushkin Level 1 DD3500 2x256
AIW 9800 Pro
At 2.7VDIMM, do I need to raise this to get any higher? On the 2700 it was running at 5:4 and im trying at 1:1 now, would that be the problem?
Any ideas?
It's running on:
P4 2.6C
IC7-MAX3
AIW 9800 Pro
Any ideas?
