burningrave101
- Sep 9, 2003
NEVERLIFT said:Yep I just showed you a cheaper CPU thats running over 1ghz slower is beating or damn tied the P4's in those certain benchmarks. If you look at the whole review you see the AMD's beat the P4's in pretty much all the benchmarks.
I rest my case.
P4 is bloated and discontinued. intel is moving on with the Pentium M and dual cores.
There you go again going COMPLETELY off topic to try and prove a point that has no point. This thread is about multitasking. It isn't about anything else but that. If you can't comprehend that then just click on the little X at the top of the page and stop replying.
The reviews you have linked to do NOT show the Athlon 64 to be better than the Pentium 4 at multitasking. And you know what? Your not going to find any reviews that show that because the Athlon 64 can't beat the Pentium 4 in that area.
Take a look at the review i just linked to at Tech Report. Its a recent review that covers a wide range of benchmarks instead of just a handful that primarily consist of gaming benchmarks.
The Pentium 4 Prescott chips aren't any more expensive then an Athlon 64 so there is no real price advantage by going with AMD any more.
You just can't seem to understand that there is no "fastest CPU" until that processor is capable of doing EVERYTHING faster then every other CPU. And currently the Pentium 4 and Athlon 64 are both far from it. They are both very fast and they both have their strong and weak points. The CPU thats better is the one that is the fastest for the extent of the games and applications you run.
NEVERLIFT said:Well said.
Its always well said when its something positive about AMD and something negative about Intel lol.
