Being a newbie I was wondering...
I had been running my Q6600 at 9 x 333 and decided to try 8 x 400.
How does lowering the multplier and raising the FSB affect the voltage requirements? And vice versa?
I had to bump my voltage a tad going with a higher fsb. Fwiw I ran stable @ 356x9 at stock voltage (1.28v) but had to bump it up to 1.3v to go 400x8.
Common push it more!
Set a vcore of 1.35 and go for 3.6 GHz. If tempartures allow of course..
Most quads require at least 1.4v to hit 3.6.
A "Burn in" period is not necessary.
How long should I stress test the CPU to see if it is stable at this speed?
Apparently I got hold of a good one since the voltage does not need to be raised much?
