I have a question related to USB Hubs. My PC (an HP Pavilion SlimLine s3100n) has four USB ports in the back and one in the front. I have so many peripherals (four external hard drives, webcam, USB speakers, keyboard/mouse, printer, memorystick etc.) that I am using two powered USB 2.0 hubs. One is a 4-port Belkin, the other one is a 7-port D-Link. Each one is connected to the back of my PC directly, so they are not chained.
My questions:
1) Is the order in which I connect the various devices of any importance with regard to performance?
2) Does it make any difference (performance, stability) if I connect all external hard drives to the same hub, or distribute them amongst both hubs? Keep in mind that each hub is directly connected to a different USB port in the back of the PC, they are not chained.
On a related note, my external Hitachi 1TB "EasyDrive", which is connected to the Belkin hub, is not recognized properly when it is turned on before booting up. I have to keep it turned off until XP is up and running, then turn it on. I haven't tried connecting it to the other hub (D-Link) or directly to the PC to see if this makes any difference. any opinions?
Thanks!
-J
My questions:
Thanks!
-J
