Multiple Stop Errors
I continuously receive 0x000000d1 errors every time i try to run a program on my new pc. System specs are a Athlon 64 cpu, ATI X800 video card, 1 GB RAM, 250 GB HD, foxconn motherboard. Any help would be great, as its really frustrating me.
I'm assuming this is Windows XP. Generally that error (0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL) is the result of an outdated device driver.
The system attempted to access pageable memory using a kernel process IRQL that was too high. The most typical cause is a bad device driver (one that uses improper addresses). It can also be caused by caused by faulty or mismatched RAM, or a damaged pagefile.
Resource Kit article
Memory can be the cause of many stop codes. However, I've often blamed the memory when something else caused the problems. Just don't jump to conclusions too quickly
I just tried another good stick of RAM, and I'm still getting errors. Any other help? I'm getting desparate here...
