Hi All,
We have 6 small offices which are in need of a better backup solution.Each site consists of one main computer (reception) which runs a specialised surgery software and 2 or 3 other computers (surgery pc's) connect to the software (Like MYOB for e.g.). We currently run 2 x external drives on each main computer and use acronis backup and recovery for backups.Acronis does full backups on Tuesdays and Fridays and diff backups on the other days.It is then replicated to the second hard drive which is taken off site each afternoon.The main computers at each site are the only one's that need backing up.I would like a better solution as the the external drives often playup.
I'm after some ideas on alternative solutions that you could recommend.I'm open to all ideas, And can use other software if acronis is not considered the best setup.The computers at all sites are a simple workgroup setup.
I should mention that all sites are kept separate as they are completely independent.
Any help would be greatly appreciated.
