I picked a Tyan Tiger100 MB (dual slot1) to replace my old CUSL2 as my file and web server. Swapping everything over, I'm finding out that having my Promise Fasttrak Tx2 and Adaptec 29160 can't interoperate more or less on this board.
Depending on how I have the PCI slots scanned - first to last/last to first (akin to moving the cards around); I can have the scsi adapter boot, but then the RAID BIOS doesn't show and I have no access to the array. Or I can have the RAID init but skip over the SCSI and not boot at all. Mind you my boot drive is a scsi drive.
One work around I sorta got is to disable my scsi adapters int13 support. If I do that and have the scsi card init, then init the raid card - of course I can't boot off of scsi, but it either has to boot off of the RAID. So its something about the BIOS and a card sending it a command that it can be bootable and the bios then tries to boot. If the Promise card had some option like that I could do boot this computer.
Anyone have problems like this? I was thinking of swapping the card out and getting a Highpoint, but I may run into similar problems - if it doesn't have a int13 option. Anyone have experience with this? I never did have this problem with the CUSL2.
