unhappy_mage said:Well-written drivers shouldn't require that the card's BIOS execute. I haven't had opportunity to test this, but Supermicro assures me that it works for my card. YMMV.
As he described it, it does. However, it may be something else; I'm not familiar with the subtleties associated with writing firmware or drivers. Do most OS drivers re-initialize the card from scratch, or use values left for them by the card's BIOS?Cript said:which resulted in some being skipped and the card not working.
unhappy_mage said:As he described it, it does. However, it may be something else; I'm not familiar with the subtleties associated with writing firmware or drivers. Do most OS drivers re-initialize the card from scratch, or use values left for them by the card's BIOS?
AreEss said:... which has absolutely nothing to do with the problem that Cript described.
It has to do with the boot and load order at POST. Not drivers. Nothing to do with drivers at all. Many cards are braindamaged and presume that they'll be the only card on there period, which results in problems. LSI has the exact opposite; only a single BIOS will load for multiple cards of the same family (e.g. 320-1 pairs,) but both cards can be controlled through it. Adaptec won't play with anyone, 3Ware won't play with anyone, and Areca's untested.
